T-Mobile LG G3 New Lollipop Build
hey the tool was updated il try again if it doesnt work ol try gettinn the update from a torrent site or somewhere
Title
LG G3 D851 SOFTWARE UPDATE
Content
Operation
Product type
Mobile > Cell Phones
Date
06/11/2015
Do you have a white or black phone?
The racist folks at LG will not let the update tool work with the white version.
If you have a white G3 and get the new update loaded, please post.
I've had to reboot twice already today. .
i got the white phone it says the phone already has the latest and it wont update the white phone
Sigh....... Yep......
Reboot
i found this is this what i need to download and install ??
KDZ available for D82120E! | T-Mobile LG G3 | XDA Forums
update i updated it with that file n some flash tool i think i borked it or broke it some or just damaged the phone when i start up the phone now it says the wearth needs to be set up but i did that a while ago i set it up restarted n it needs to be set up again so its maybe broke i aint sure im sad now cuz lg wont fix there to to work with the white phone :(
ok i have a problem it seems i may have broked my phone :( this wouldnt happen if someone contacted lg an told them to fix there stupid update tool to work with the white phones :( il put an update later :(
Ok, so did you use the instructions from XDA? .
You said it hosed your phone up the other day. . How did you get it running again?
AND......... most importantly, does it work as good as it did on KitKat?
i did the flashing thing it seemed to work xcept the weather app forgot the location but after a restart of the phone it all started working again i only had kitkat for a few days be4 i updated to lollipop but to me the phones workin ok now but im only keepin atleast 2 or 3 more months then im gettin the LG G 4
Thanks, I guess that gives me a project for tomorrow.
I have not yet updated to D85120e. I am still running Kit Kat on my LG 3. I have just one question...I keep getting the update notice...Is it worth it to download the Lollipop update? I have very few complaints with my LG3 except for occasional WIFI calling issues. I have not heard anyone saying " this is one download you need to get". Yes or no???
LoL get the update it has the wifi fix LoL
I just got that new update this morning and now I can't connect to my wifi. I need help on this 1
Try rebooting the WiFi router and see if that helps. If it doesn't, then consider clearing cache through the recovery menu. Be sure to clear cache only and erase data/factory reset as that will erase the device, including internal SD card.
Yea I tried that and it's still not connecting to it or if it does only for a short time
I am beginning to think that maybe T-Mobile update D85120e does not have all the problems that the first Lollipop rollout had!
I have not found many complaints about it as I had after the first rollout. Maybe they did it right this time.
I'm still terrified to try it. T-Mobile sent me a new device and advised to ignore updates, which I have. So it's back to KitKat, 2 day battery life and responsive performance. Not sure if what I stand to gain by trying this Lollipop fix is worth the risk. It was like running the G1 on Gingerbread.
So is this update stable and fixed the battery drain and heat issue? I really want to update but the last one killed my phone and T-Mobile had to replace it. KitKat runs fantastic but I want the VolLTE functionality Lollipop provides.
doxidex23
