T-Mobile LG G4 MM Stock images and KDZ
Don't be in a rush to get Marshmallow, there isn't a lot of significant improvement over Lollipop.
So, my only gripe is about the way one must long press the home button to access Google Now via Goggle on Tap. Other than that, there is not much of a difference. Also, have not figured out how to enable advanced messaging on LG native SMS app.
Here is what I notice so far:
Android Pay works with knock code.
Can toggle silent with volume and vibrate.
Quicker to unlock.
Dialer added video calling option
Battery life seems worse but not by much.
Doze didn't do much(left off the charger overnight for 8hours and went 97% to 87%).
Added most shared to contacts at the top of the share to options.
When making a choice to use an app, the box is not checked that says "use as default app," so now you can just hit ok and it will use the highlighted app. Small change but awesome!
Brightness slider defaults to current brightness when toggled off of auto instead where you set it. Can now toggle 0,50 and 90% though.
Couple things changed in settings like a Google tab, and ram monitoring.
Anyone else having Wi-Fi issues after upgrading? I can't connect to some networks that I was able to before and on the ones that I do connect to are constantly dropping.
LG just informed me that the update function has been removed from LG Bridge. So the only option is to wait until T-Mobile pushes it out to me.
11:00 p.m. on February 21st 2016. No notice yet on my LG G4 that an OTA update is available. Still has the "your system is up to date" notice
Yet when you go to the Tmobile site it says LG G4 is good to go.
Guess I will stop in a t-mobile store tomorrow and see what's up.
pramanj96
