But it doesn't stick....
The "LTE only" option doesn't stick. You can select "LTE/gsm/CDMA auto(prl)".
Its tons of threads about users using lte just fine and guess what its still on 4.2.2. To the op lte works just fine on the n4 T-Mobile is bringing out lte on the frequency it runs on.
Sent from my Sprint Galaxy Nexus rockin 4.2.2 using Tapatalk 2
The Nexus 4 will never officially run on tmobiles Lte. Anyone that is running it on 4.2.2 has flashed the old radios, because the new ones have Lte disabled as required by the FCC.
Sent from my HTC6435LVW using Tapatalk 2
Here is the fact. Nexus 4 as we know sells officially by tmobile. And it had to go through testing by FCC. FCC done testing it on tmobiles network and passed it as well as other networks(not particularly for lte because none of US carriers have it for sale) . But it doesn't matter. At the time of testing FCC couldn't test LTE on nexus 4 because tmobile wasn't ready. So it is possible that Google and Tmobile agreed with fcc to do further testing for lte after tmobile official lte deployment. Meanwhile google disabled lte through the software. Would it be a reasonable explanation why n4 got functional lte but its been disabled for aahh network interferences.. Or FCC order.
Did note 2 get lte enabled by software update?
Well, until today no US carrier offered Band 4LTE. T-Mobile rolled it out today, and now plenty of people are making it work.
Is solavei's lte bandwith compatible with te nexus 4's radio capabilities?
Yeah
The note 2 did. T-Mobile also has made it very publicly known that the note supported lte.
Do me a favor and go look at the list of handsets tmobiles network will support for lte. The Nexus is not, nor will it ever be, one of them.
The lte was disabled because the Nexus 4 is not certified to access it, and Google and LG will not be submitting it for recertification. By not locking it, Google was technically violating the law by allowing devices to access a network which they were not certified by the FCC to have access to.
Yes it did
So when they do expand am I gonna have to buy a new phone. Will they continue to support and expand the current Hspa+ ?
TMO won't shut down HSPA+ for at least another decade.
But will they continue to expand it??
Doubt it. It would be easier and probably cheaper to just roll out LTE instead of doing both at this point.
That sucks...
