T-Mobile October/SA 5G update out today
Right hasn't there been a 2nd October OTA?
Latest unlocked which is this one on SamMobile.
This the steps and tools you'll need, get from xda site .
This is the steps :
Windows computer needed
Latest Odin can Google it from XDA Forums and download the latest should be Odin 3.14.1 / and Frija tool or samfirm (i usually download both)
Download samfirm v0.4.1 tool and frija, extract it with 7zip.
You will extract files for Odin prince comsey 3.14.1once download with 7zip and will do same for firmware with 7zip .
Put your model number then region and select check for updates , then download the FIRMWARE , extract the FIRMWARE with 7zip.
There will be 4 files after you extract the firmware
BL
AP
CP
CSC
Each of those files will go in Odin when you open to the corresponding slots
BL
AP
CP
Home slot don't out anything
CSC USE HOME CSC FIILE TO SAVE DATA /THIS ONLY GOING BETWEEN CARRIER FIRMWARE OR IF YOUR ON UNLOCKED GOING BETWEEN UNLOCKED FIRMWARE
If you going from carrier to unlock firmware keep regular CSC not home CSC and do a back up it will factory reset the device.
connect your phone with cable to computer , once the files are in its slots hit start, once done you'll see pass in Odin and it will reboot
*Make sure you put phone in download mode
*If dont see your phone connected in Odin change cables or ports in computer .
*Never disconnect the cable in middle of flashing.
Questions, if going from unlocked to tmo use the regular cyc file? Or Home CSC...
Anyone having wifi issues since the Oct update? I have to use my cellular data because its being very slow, I didn't have this issue until the Oct patch happened. I even tried a network reset but didn't help.
I thought I was back to having my no update issue until I saw you haven't gotten an update from AT&T. They are just super behind. Lol
No sweetypie, I just saw something on SamMobile that said Samsung just released the November Security Patch for Note 20 Ultra and I thought, "Oh GREAT - November is released and AT&T hasn't even given us October yet!" Love it... we should have bought "Unlocked" like Katrina did! I definitely learned my lesson this time.
Anybody know how to tell if you have the 5G SA? Just got the beta update with Nov security patch. Not sure if there will be a different indicator or not.
I have my att sim now not my Tmobile, but voice mail working and I got wifi calling on unlocked Att
slackingfred
