Tab S 8.4 LTE battery drains extremely fast and erratically
I had exactly the same thing with my Tab S. Erratic battery performance - it would drain quickly from 100% to 50% (if I was actually able to charge it up to 100%). At about the 50% level, I would start to get horizontal flashes across the screen. The battery would drop to 10%, sometimes it would spontaneously reboot. Upon rebooting the battery would be anything between 0% and 50%. If I plugged it in to charge without turning on, it would sometimes charge up to 100%.
Anyway, I dropped it into Samsung. I picked it up today and they said they'd replaced the main board (!!).
Hopefully it has fixed things. Maybe they did that just to get a good battery connection - who knows.
Thankfully it was all under warranty, and it was fixed in about three days without much drama.
I had the same issue on my brand new Galaxy Tab S LTE version with Exynos chip. I was like WTF on the battery because the moment i disconnect it from the charger it would soon drop to about 85% in 5 minutes.
Then the dropping continuous in huge leaps like from 70% down to 30% while i'm just browsing the web.
Then when it came down to 5% it would turn off.
The moment i plug in the charger while the device is off the battery level would start at 40%.
I was able to resolve this without doing factory resets:
What i did was the moment the battery came down to like 5% i completely turn off the tab and turn it on ,
the tab reported a higher battery level like 45% then i continued using and until it drops again to a lower level like 3%.
I power cycled the tab again and it reported battery level at around 24%.
I used it again until battery level went to 3% and rebooted it,
then it reported 12%.. Used it again until the device really wont boot anymore.
Then i used a slow charger. I used the 1A usb charger from my other phone (while off) and waited until 100% full.
Then things became normal.. it reports battery level fine after.
I resumed using the 2.1A default charger and 'the issue' doesn't seem to repeat anymore.
This ^
For me replacing the battery with a new one found on eBay fixed the issue! New batteries cost around $15 now.
Guys
Having terrible battery drain bought another battery but same problems, went to safe mode, no different, done factory reset still no change, any ideas, tablet is 2.5 years old.
jacketempire
