Tempered Glass Note 10+
I agree it's hard to say. But it looks a bit frosted. One pic shows a white phone but there case makes it look a bit gray.
It is a little frosted, not bad in my opinion. I will give it a thumbs up that it doesn't show fingerprint smudges, a huge plus to me. It will scratch though and those start showing. To me, it's worth having the clear smooth look without the smudges, I'm willing to buy a new one in six months or get the d brand grip case as it will take them 6 months to release that, dbrand is always late to the game.
When you go to uag website it will ask for your email in a pop-up, you will get 15% off if you do that. I know that means crap load of email coming, but there's a unsubscribe button in those emails, problem goes away. Ordered my case Thursday, shipped yesterday for Tuesday delivery.
I was set on the Whitestone until I came across a website with nothing but bad reviews. Apparently a couple weeks in they end up having issues and their customer service is terrible.
I cracked mine and they sent a replacement. Not sure what you mean about their customer service. I think you can find bad reviews on almost anything
Whitestone is so expensive. Are there any alternatives for less?
I agree they are expensive. But I think they are best for the curved screen. I've read too many problems with other brands and don't stick or respond well.
If the phone had a flat screen then I would agree that most other glass protector would be fine.
You want quality on a 1100 buck phone, you gotta shell out the dough
I'm never going back with white stone again. I dont know what they did with their glue but its horrible on the note 9 and s10. it cracks around the edges horrible after a few days
Are you sure ?! It works fine on my 9 with no issue at all
I'd suggest to wait until we see the available screen protectors on the phone to see if the fingerprint sensor then works.
My preference is the Whitestone Dome Glass screen protector option as long as things work as they should.
Gotta say my Whitestone protector has saved my phone a couple of times. Once I closed my s10 in my car door as it fell out of my pocket. Screen protector cracked and not the screen. Other two times were from drops, screen protector cracked but not the phone. My uag case too has served me well from a few nerve wrecking drops. Both together for me anyways has done its job :) so I'm going with the same combo, tho I got the plus so more screen to potentially break unfortunately :/
It less expensive than trying all the ones that don't work. The Whitestone works with the FPS, the less expensive ones do not. The cheaper ones use edge adhesive which cause too many problems like, no FPS support, rainbow effect and other issues. I had a Whitestone on my Note 8 for 2 years with not one single issue. Well worth the price.
Problem is just: while it works for some people, for others it doesn’t. FPS never worked on my S10+ with the dome. Had it replaced twice, no change. The reviews are also a very mixed bag. So in my opinion: no, it’s not worth the price tag.
So which one do you use?
I have the whitestone dome screen protector on the phone now. The only problems I experienced is when it's trying to scan my face at the same time it takes it a bit longer to register my finger. Other than that it works the same as it did with the preinstalled screen protector.
kitlis
