Tempered Glass Screen Protector s6 edge +
I actually got the Spigen Crystal HD from Amazon last week. The description said "curved crystal" so I was thinking glass-like. While it is a plastic film, it's not nearly as bad as I thought it was going to be. If you dig your fingernail into it, you can tell it's a film covering the screen, but just normal use, you don't really notice any dragging or friction as you would on a lot of other films.
Just found these on amazon, if you want to pay $40: http://www.amazon.com
Available on the 19th.
I came across a few others that are also cheaper, but delivery is set for mid-late October.
I have the Spigen one as well. Was disappointed it was a film but it is working. Edge to edge coverage for the most part and certainly does not feel sticky like film. It is not as smooth as glass but for a film it comes pretty close. 15 bucks direct from Spigen. I did email Spigen to see if they were developing tempered glass and the reply I got was that they are not even considering it at this time due to the difficulty and cost of development.
I have the Spigen Crystal as well, but it accumulates grease relatively quickly and smudges everything up. I've now ordered a Chinese glass one, if that one sucks (which I'm semi-expecting), I'll go naked on this one.
Doesn't that cheap plastic feel awful against your fingers after a while? I can't do cheap plastic screen protectors, I just can't stand how they feel and how they collect grease and smudges so easily.
Posted via Note 5/AC App...
When I first used it, the protector felt grippy compared to the glass, but after a short time it felt normal.
I just received the Jettech tempered glass screen protector. Very unhappy. Edge functions were very difficult to get to work. Screen was very difficult to see. I'm sending it back right away. I really want to go naked but I'm afraid. Although after spending a mint on this phone I want to enjoy the beauty. And for $60+ extremely disappointed.
I'm using the Tech Film and I love it. After a day or two you literally forget it's there.
Has anyone tried any of the eBay tempered glass? Saw a listing that had 1,500+ sold on it.
Sent from my SM-G928V using Tapatalk
Verizon is showing a ZAGG InvisibleShield HD DRY for Samsung Galaxy S 6 edge+ - Full Body for 29.99???
Wow a thin clear plastics for more than half the price of an Amazon tablet. Ouch.
Sent from my Z970 using Tapatalk
+1 for TechFilm. Tried a couple different ones and TechFilm is by far my favorite. Nobody knows I have a screen protector on.
I haven't seen this posted yet, but Skinomi has a Tempered Glass screen protector for the S6 Edge Plus... I ordered my Tuesday and it got here Friday.
Skinomi Tech Glass - Samsung Galaxy S6 Edge+ / Edge Plus Black Full Coverage Glass Screen Protector w/ Lifetime Replacement / Ultra Thin Premium Tempered Glass - Clear 9H Hardness - Oleophobic Coating
https://www.amazon.com/dp/B014K3471...ag=hawk-future-20&ascsubtag=UUacUvbUpU4708712
How is it?
I can't post a link as apparently you need at least 10 post to do that, but if you search ebay for
Galaxy S6 Edge+ Plus Screen Full Cover Film FrontBack Clear Screen Protector
You will see it.
The seller has increased the delivery price since I bought it though.
Best option is put tempered glass screen protector and use wallet or hard case. Due to curves it's not guaranteed that after a drop screen will be the same or not. On eBay you can find some tempered glass screen protector for $10.00 to $25.00The not to drop it.
May I deer to recommend you an Alien Shield protection? It will cover your front, back and sides with an invisible and strong material.
Trimis de pe al meu SM-G928F folosind Tapatalk
I got the Tech Film. It's invisible. Application was easy. 1 day and microbubbles were gone. It feels good too.
It is a good screen protector but know that it has a notch for the camera, not a hole. Weird because the sensors and the speaker have a hole....
mersy78
