- Aug 21, 2014
- 4,471
- 299
- 83
Was at Best Buy today to get more time using the S8. Got a chance for a side-by-side with S7 Edge and just noticed something and wondering if this is across the board change...
if you look at the text at top of home screen and layout of calendar, the S7 Edge test goes Edge-to-Edge getting distorted at the curves... but the S8 text doesn't go to the edges.
I had thought icons and texts looked narrower and thought it was mainly due to the phone being a little narrower than then S7 Edge but if they are also not stretching text Edge-to-Edge then it seems there is less text space then per line?
