Texting not working.
2nd and 3rd links are broken :(
They worked for me when I clicked on them in both my post and your reply. What are you seeing when you click on them? If the links are broken just go to the Fascinate Rooting/ROM's/Hacks section, you can find them there. Second link is one of the first five or so threads, and the third link is on page of the rooting/roms/hacks section.
Reactions: ThePlasticBling
Yeah I retried and they worked :)
I think I understand more about my phone. How about we get to fixing and restoring this puppy.
I am going to have to leave you in the hands of more capable experts at this point. I know how to flash different builds through ODIN, but with your particular situation being on a completely different baseband and build, problems may come up I wouldn't know how to fix and I don't want to leave you in that lurch. Have a little patience and someone will surely check this thread and help you.
Well I really need to get my phone fixed by tonight. Do you at least know how to restore apps and data with titanium backup after restoring a phone using odin?
Do you think instead of that I could use the SuperClean 2.2 with Voodoo from http://forum.androidcentral.com/ver...ks-roms-themes-kernels-updated-2-13-11-a.html or would that not work?
it would but honestly i dont think you need it , i was using it yesterday and i dont see any difference at all, it will just cause you more problems in the future if you are not carefull disabling ,,,,just flash superclean 2.2 with my odin flash, give it a day and if you think its terribly horrible then you can try voodoo later, this flash will root you and install clockworkmod so later on you can go head and flash the voodoo if you thinks its necessary
couple things, please make sure you disable lagfix you have now
also after you flash superclean
go to settings>privacy>and disable auto restore,,,then you can sign into your google account,,,,otherwise it will try to download every ahpp you ever downloaded
OK, I'm downloading it. Should be about 20 minutes. But I still don't get Titanium Backup. If I restore my phone, How can I restore everything if Titanium backup gets deleted?
when you backed up it created a folder on your SD card,, when you flash odin it doesnt touch your SD card so everything will still be there,,,if you want to verify what im saying, go head and hook up your phone to the computer, mount your SD card and look in the titanium folder, there will be another folder inside called back up i think,,,in that folder you will see a bunch of files and zip folders , thats all your backed up data
OK. It's done, but now I need to wait until me battery is 40 percent so I can remove OCLF
in the mean time right click on that file you downloaded and select Extract here if you have not done so already
and i understand you want to save your angry birds level but i think being able to make and receive calls is proiority correct?
Don't forget about sending and receiving texts. That's a priority too.
Yup, lol. And I just removed OCLF. Shoot I unroot my phone too, or just continue on with odin? Also, will OCLF work with the file you told me to restore my phone with using odin?
the file will overwrite your recovery ,,,, but it will also give you root, froyo, clockwork recovery.... then later on we will help you get the voodoo clockwork recovery if you feel you need it
Forget OCLF, and just follow what DXC is telling you, he is THE expert. I should know. I just rooted or did any customizing on my phone less than a month ago thanks to considerable help from DXC because I was a complete noob. And thanks to that same help and advice here I am less than a month later helping people. Put your trust in him, he nor anyone else in these forums will steer you wrong.
lefler
