Techno-guy
- Jan 13, 2015
- 449
- 0
- 16
Doesn't the "close all" button when you open the task switcher already kill apps in the background? If not, then what the heck is the point of it?
No,
The "close all" button only closes apps you have opened recently, but there are many apps that still run even though you have not opened them but are installed on your phone
For example...Shazam (the music recognition app) always runs in the background, and will often auto start running in the background even after u closed it from "close all"
No,
Yup!Woa, I didn't know that. Uninstalling Shazam now. Thx!
There's a difference between an app still being in RAM (there should be as many apps as possible in RAM) and an app actually running and using battery. App killer apps are written by people who think that Android runs like Windows when, actually, it's about the opposite of Windows. As naviman said, removing apps from RAM kills the battery, it doesn't save it.What I have noticed though is that there are background apps that are draining my battery (for example, my radio apps).
Well this app must be doing something right, because my battery was horrible before it...this phone now lasts longer than my Z3!There's a difference between an app still being in RAM (there should be as many apps as possible in RAM) and an app actually running and using battery. App killer apps are written by people who think that Android runs like Windows when, actually, it's about the opposite of Windows. As naviman said, removing apps from RAM kills the battery, it doesn't save it.
Read what someone who actually wrote Android code says: Multitasking the Android Way As a systems developer, I know better than to argue how the code works with the person who wrote it.
What you're seeing is confirmation bias. With no apps running in post 7, killing the apps that aren't running is like the reason there are no elephants stampeding in downtown Honolulu - I know someone who's using his psychic powers to keep it from happening. (At least he thinks it because he's using his psychic powers.) The app is killing apps that aren't there to kill, but it's using battery itself - but since you've convinced yourself that it saves battery, you'll stay convinced. (BTW, Greenify is trivial to use - just don't Greenify apps you want running, like Phone, email and text. That really saves power, because the Greenified apps can't run on their own - something has to run them, like you tapping an icon.)
How long were you using the phone before installing the battery? Most have reported increased battery time after a number of charge-cycle times. It's possible that you would have increased battery life even without having installed the app.
The only way to know for certain is if you had 2 phones treated identically, one with and one without the app.
I suppose you could try to uninstall the app and see if your increased battery life persists.
I got the phone on release day and my battery was never as good as this before the app... Even after doing all the recommended tweaks... This app must be doing something rightHow long were you using the phone before installing the battery? Most have reported increased battery time after a number of charge-cycle times. It's possible that you would have increased battery life even without having installed the app.
Yup!
Check your Application Manager in Settings and go to "Running" and you will see the apps that are still running in the background
Sent from my Samsung Galaxy S6!
Has anyone tried this on LG G3?
Kindly let me know....
