The officially unofficial "Optimized For Honeycomb" List (n=292)
I'm planning on adding an authentication option soon where it won't require your email/password for authentication with Google. But instead, to pull the Google account being used by the device.
That would be good to have, and would work better for folks using two-factor auth on their Google accounts. Would this also integrate the app with the Sync Manager on the device (to control periodic updates to the app)?
Also, any plan to support folders?
Reactions: 1976AD
I hadn't considered the Sync Manager, but I'll look into it. Thanks!
I pushed 1.3 late last night (early this morning?) that has this functionality.
I'm using Jorte calendar, and the it looks great on my zoom, especially the month view. Way better than the stock calendar in my opinion, and it's free.
I don't think I saw it listed, I might be mistaken.
Jorte works for honeycomb. Best calendar Widgets IMO
you were mistaken :p
but I agree, Jorte has the best calendar widgets...I can't believe there isn't a better google calendar widget out there
It may not be designed for honeycomb, but flight control works wonderfully on the Xoom. Angry Birds Rio also works perfectly on Honeycomb.
I have spent some cash on a lot of games and apps.
Is the OP / Stick list being updated ? I can do some work to list the apps I'm rocking, but that list is not as fresh as possible.
there are apps/games missing but that depends on if: "optimized for honeycomb" = "works on my Xoom".
good list, I just bought another damn game because of this sticky ! Thanks, and I hate you at the same time :)
AC
Tapatalk works great and so does google TV remote if you have google TV. They are not in optimized but work great. I do find some don't work right or fill the screen.
Sent from my Xoom using Tapatalk
Yes I am definitely liking tapatalk.. I'm a big forum user! Thx for that link
AC
I'm only listing the ones that are specifically optimized using the new fragments UI or if not that, make use of the tegra2 or are at least made for large-screen tablets. That is why the list is so short. If I were to list all the apps that work on the Xoom, damn near the entire market would be on the list.
I'm wondering if it would be worth having a list of apps that don't work on the Xoom (or that work on the cellular Xoom, but not on the wifi-only Xoom)? I've run into a few such apps.
im not sure if rockplayer is optimized but it works on the xoom!
the only issue is that if you keep re-sizing the video size while playing, the program freezes and force closes
papicef
