[Theme][Port][Comm ROM 2.0] White Chrome v3.0 June, 3 2011
A newb question: How can I use a launcher pro Icon on a homescreen? When I try to choose a "custom icon" it just takes me to my Image gallery.
Go to Settings > Applications > Manage Applications and click on the All tab. Look for "Gallery" and click on it.
Here choose the option at the bottom "Clear defaults"
Next time you go to choose a "custom icon" it should display a list of applications other than Gallery to choose from.
You must have in the past set "gallery" as the one to use by default.
Nope. I need to know a location of WHERE the Icons are located. I can do the mechanics, I just need location.
Edit: This sounded snarky, not my intention. I want to change the ICON of an item on my HOMESCREEN not on the DOCK.
when you long press on the icon select launcher pro icon. other wise wait 5 minutes for me to resize and upload the ones i have.
That works for icons on the docks, Should it work on the homes screens as well? Long pressing an Icon on the home screen just gives me the option to remove it.
no it wont for the home screen, but the icon pack is up, there are like 57 icons. unzip and drop on your sd, then select custom icon. it will take you to the gallery, it will be where you put it.
Reactions: Mtn_Scott
Is there a way I can resize the icons in the icon pack to the same size as the launcher pro dock icons? Maybe in paint on my computer?
NO!!!!!!!!!!!!!!!!!!!!!?!!!!!!!!!!!!!!!!!!!!!!!!! Thats the trouble. No matter how big I make them they are to small. Im working on it though.
Sent from my SCH-I500 using Tapatalk
Sorry I missed ur comment on the subject on page 2. After re-reading all the posts i caught it. Wasn't try to be an ungratefull arse
No, no. The frustaition is not with you but the launcher. It doest make any sesne. I am consulting with an lpp expert and he is stumped too.
On another note, arse is such a funny word.
Wuts funny is when you long press them on the home screen to,move or delete they enlarge to the size of the launcher pro icons.
Not sure if this makes it better or worse, but I actually like the smaller home screen Icons. It actually makes the Dock Icons "POP" a little more. Especially with all the Icons matching, I like the differentiation. Once again, thank you for all the hard work on this. I expect to be staring at this theme for a long time.
Not to make your predicament even more annoying, but if you put Gmail on the dock, the stock Icon is smaller than if you put it on the desktop. Weird.
Eeeeeeeeeerrrrrrrrrrr!!!!!!!!!!!! I hate you!!!
olivie
