[Themes] HoneycombS, Alpha7 and Orion *4/13/2011*
does this theme have a battery percentage meter where the battery is located (on the status bar) just like the ThundeROM theme ??
I only ask because I didnt see it on the main picture on the first post
Nope, just the battery....
I want the blue notification colors like Nick's pic instead of hard to see gray
all the images in this are from the system dump for honeycomb with the exception of the battery...it looked weird...
I'm trying to keep this as "stock" as possible. Variations may happen but later.
I ran this on nROM 1.6 and the only problem I ran into was the CLOCK app force closes. Tomorrow if I have some time I will try another alarm app and see how that goes. Other than that I did not test every aspect but, Great job!!!!
what exactly does this theme change? does it also theme the dialer? from the pic on the 1st post it just looks like a wallpaper
I haven't ported the thundeRom dialer out yet...that is on my todo list
cm7 version:
honeycomb is based off gingerbread so the dialer is the same regardless.
with the exception of specific UI elements that you can only use on 3.0, honeycomb is gingerbread with new icons.....
Reactions: omarnova
Like it was stated before, the clock FC's on nROM. Other than that, it works fully. Gob job! Can't wait for the updated icons.
looks good :D
One thing I notice using this theme, where you'd normally have a check box to make a selection, there is nothing.(i.e. "remember me" for logging into forums, avoid highways setting when getting directions in google maps.) Otherwise it looks good! Tr 1 8.2
Algarañaz
