[THEMES] Optimus s Gingerbread Themes
Re: [THEMES] Optimus s Gingerbread Themes (WIP) -- 9/22/11
Husker (nebraska) football theme ?
I see these themes work with the opti rom. But will the other stuff in this theard work also? I really like the dark google search and the notification icons. BTW thanks for all your hard work. Man these themes really rock!!
Reactions: jstntp
Thanks, and yes everything is good to go with Opti-ROM.
Reactions: dobbs69
Yeah I can confirm that everything works on gROM and optiROM. Currently rockin chill out theme with dark google/sms and I made a swype beta keyboard that is black with blue lettering that matches the theme.....LOVE the way this bad boy is lookin lol :)
[INFO]****UPDATE****
All themes (current and future) have been updated to disable the background process IQ Agent automatically. Read about it here.
Also I recommend everyone redownload and reflash any themes you are using currently as they will be better compatible with future custom ROM releases.
[/INFO]
Reactions: basketthis
Ok so I tryed to flash the reborn theme an wen I rebootef it just put me un a boot loop iv tryed it a few times an the same thing. Not sure what happens if someone got any ideas that would be awesome thanks
Let me take a look at it. What ROM are you using?
Dude, whats it gonna take for you to port some of these over to the Evo 3D? Im tellin' ya man, these awesome themes!
I need a 3d!! Donations accepted. lol ;)
OK here is my setup. Running opti rom and downloaded the reTouched theme from the OP. Went to recovery wiped dalvik and cache then flashed reTouched-noIQ. Took awhile to boot, but it booted fine. Make sure your not wiping data though.
Maybe redownload the theme too.
I was wandering what all can be deleted out of system that you don't need so I can get the most mb? Like barebones only have the nesesary
If you cant get it to work, I will send you the original that does not disable IQ Agent and you can try that. I am curious now if this is going to be an issue for others too.
I have the original ill try it an see
edit: the original one worked. Do you have the noiq.zip ill try to just flash that by it self an see what happens?
Here is the link to reTouched-noIQ again, same as in the OP. All the files inside are the same as the original reTouched for GB except one small edit in one of them. You can flash it without wiping anything. But if you do, only wipe dalvik cache and cache. It may take a long time to boot, give it a solid 5+ minutes.
theme_GB-reTouched-noIQ.zip
Was wandering if u had a noIQ.zip I got the original zip to work but I want to try the noIQ an the link above wont download for for dome reason
That is the noIQ zip and it should download now.
Ok its just the noIQ not the theme an noIQ? An ill try again but it just comes up page cant open an wen I finaly got it to open the download will just go to fail
edit: the page cantains to many server redirect. That's what it comes up with wen I try to download it
ChrisAndroid
