[THEMES] Optimus s Gingerbread Themes
Re: [THEMES] Optimus s Gingerbread Themes (WIP) -- 9/18/11
Yes they should. I have not tried yet though.
EDIT: Yes, I tested them and they work just fine!!
Any possibility we can get some new boot animations? I have a bunch i found, but the resolution is off, cause they arent designed for the Optimus S. If you want i can email you the files, if you just want to change the resolution, then add them to the OP as OP #6 or something. Thanks man.
Re: [THEMES] Optimus s Gingerbread Themes -- 10/23/11
Will the dialer mods work with your momrom? and not disable the control widget in notification bar
THanx very much mate. its nice to be here and i'm hoping I'll learn to not brick my phone lol
love the chillOUT theme! anyway you could make the phone/browser buttons the same color blue instead of them being green?
Anyone have the old colorful Email, Gmail, and Messaging notification icons zip? The file was deleted. Thanks..........
The reason that file was removed is because that version of Gmail is outdated now needs to be updated. Been busy with other things and haven't had much time to put in work on this thread..........sorry everyone!
I'll go ahead and leave the zip here for ya, but be aware that it contains an older version of Gmail and if you update it from the market, you will lose the colorful statusbar icon. I would go into market and turn off "automatic updates" before flashing this. Gmail itself will work fine, it's just one or two versions back though.
Email_Gmail_mms_noti-icons.zip
Reactions: jas12 and mike9670
I want my opti-green theme back...used it on reborn. I'm using grom now, but planning on switching to Your MoM rom sometime. I'm a bit frustrated at times with the screen sensitivity.....
Any chance of a yellow theme?
Anyone working on Opti-Green theme?
Thanks for the themes :)
[INFO]As of January 2012, I will no longer be updating or maintaining this thread due to circumstances in my life outside of the Android world. My wife and I are expecting baby girl #2 here in March and well, there is quite a bit I need to do to get ready for our new arrival. Needless to say, there will be even less time to spend here once the little one arrives. I will still be around though, tinkering/modding here and there, with my Team Hydro peeps on other projects, but I'm throwing in the towel as far as owning/maintaining any work myself. Although this is a tough decision for me personally, the reasons behind it are joyous.
I would like to send a genuine Thank You to everyone who has used, supported and enjoyed the work and hopefully someday down the road I can return to owning/maintaining a few new threads.
All links will stay up and available for download and use so please continue to enjoy the themes/mods.
-Justin
[/INFO]
Congrats, Justin!
I'll bet that kid has one badass room, with drawers that come out of the ceiling and what not... :cool:
Reactions: jstntp
mms-dark (the dark stock messaging app) will not download to my sd card because it says I need to remove write-protection... how do I get around this?
Are you using your phone with usb cable to transfer the file or did you take the sd card out of the phone and put it in your computer?
hey i flashed the chillout theme but after reboot my phone stays on the android screen its not loading any help
Although I would assume they should work for you, no where in the OP does it say that they are safe for stock rom. My recommendation is either to restore your nandroid you created before flashing the theme. Or updating to gRom/optiRom/yourmomRom are they are stated as supported.
I would say no. Typically themes are based of deodexed system/app files. Stock roms are usually still odexed. So check your rom chefs op to verify its deodexed.
dumpsterrentals89
