Thunderbolt Battery Complaints + Tips/Tricks
I don't know if this has been posted in here yet (I am hoping to read through this whole thread this weekend), but I contacted HTC about the battery life along with a few other questions. They sent me a list of battery saving tips. Here it is:
1. Lower screen brightness
From the Home screen, press Menu and tap Settings Tap Display Tap Screen Brightness
2. Turn off Wi-Fi, GPS, and Bluetooth when you don't need them
From the Home screen, press Menu and tap Settings, and Wireless & Networks
3. Disable Wi-Fi and 4G network notifications
Press Menu and tap Settings, and then tap Wireless & Networks
4. Disable "always on" mobile data
This is one of the biggest battery savers. Home, Menu, Settings, Wireless & Networks, Mobile Network Settings, uncheck Always-on Mobile Data.
5. Turn off background data
From the Home screen, press Menu and tap Settings Tap Accounts & sync, and then uncheck the Background Data check box.
6. Lower the screen timeout interval
From the Home screen, press Menu and tap Settings Tap Display, and Screen Timeout
7. Manually turn off the screen when not in use
Since the screen timeout function ensures that the device's screen will turn off (unless you have it set to "never turn off"), it can be tempting to put the phone down when you're done using it and just let the screen turn off by itself.
8. Turn off auto-sync
From the Home screen, press Menu and tap Settings Tap Accounts & sync, and uncheck the Auto-Sync check box
9. Change auto-sync frequency (Weather, News, Stocks, Twitter, etc)
If you don't want to turn off auto-sync, you can adjust how frequently data is retrieved/updated. Home, Menu, Settings, Accounts & Sync, tap on the account you want to change, tap Account Settings, and then tap on Update Schedule to change the update frequency.
10. Disable wireless network location services when not needed
From the Home screen, press Menu and tap Settings, Location, and uncheck Location Services provided by your mobile network.
11. Turn off window animations
I know it's nice to look at and fun to show off, but eye candy uses extra power (albeit not very much). Home, Menu, Settings, Display, tap Animation, and choose no animations.
12. Don't use live wallpapers
Live wallpapers were one of the new features in Android 2.1, so it feels like a step backward not to use them. They don't hit the battery very hard when used, but they do make a small dent. So if you're trying to improve battery life, even if only incrementally, use a static wallpaper instead.
13. Use a dark wallpaper.
Some say that dark wallpapers are more energy efficient than light wallpapers. Others say it doesn't make any difference. Either way, there's no harm in using a dark wallpaper so you may as well do it.
14. Change Wi-Fi sleep policy
This may sound counter-intuitive, but leaving Wi-Fi on when the device isn't being used and the screen is off is actually better than letting it sleep.
15. Monitor your running services
Just because Android is supposed to an intelligent operating system that will manage your running apps for you doesn't mean it will always do things the way you want them to be done. Home, Menu, Settings, Applications, tap Running Services / Manage Applications to monitor what applications are running.
16. Choose your home screen widgets carefully
Widgets that need access to the internet to update information (e.g., Facebook, Twitter, Engadget, Slacker Radio, Weather, Stocks, News, Mail) can suck up a lot of juice if not managed well, so choose them carefully and set their sync/update frequencies to a reasonable interval.
17. Disable notification lights
This may not be practical if you're someone who really needs/wants to know when something happens on your phone when you're not looking, but for everyone else, feel free to turn off those notifications. Home, Menu, Settings, Display, Notification flash, and uncheck some or all of these options.
18. Turn off phone vibration
If the ringer is on, why do you need the phone to vibrate? Go to Home, Menu, Settings, Sound, and then uncheck Vibrate.
19. Turn off audible touch tones
From the Home screen, press Menu and then tap Settings Tap Sound, and uncheck Audible Selection
20. Turn off haptic feedback
Once you get the hang of typing on the device's on-screen keyboard, you can turn off the haptic feedback that was turned on by default. Home, Menu, Settings, Sound, uncheck Haptic Feedback.
No offense Nfuego, I know you're only trying to help.
But if I had to follow half of those, I'd have already taken it back.
I have a shoe that is quiet, has a long lasting battery and is about as useful of a device as what those tips would describe if you used most of them.
Again, no offense, I know you got that from HTC and you're only trying to help.
So what exactly is it that disabling Always On Mobile Data will do? I've always had it on, but disabled it to see if there's any noticeable difference in battery life.
It kills your 3G/4G when the screen is off. So you wont get any emails and you cant use streaming apps like Pandora when the screen goes off.
Taken from perfoliate over at another droidforums website..
I've commented about this in a couple of threads but didn't get much of a response so I figured I'd start a new thread to test this out. I'm currently running Adrynylne's Basic debloat rom with the latest .9 kernel. Over the past week I've seemed to have on again off again good battery life to bad battery life like most other folks. Yesterday I was having one of those bad battery day's where my phone just seemed to drain constantly even while I wasn't using it. Like where you can just watch the percentages fall off a percent a minute. It just seemed like the cpu was running full clocked even while I wasn't doing anything with the screen off.
I'm not one of those types that wants to turn all functionality off just to improve battery life, so just for the heck of it I setup a profile in Setcpu to keep the max cpu speed at 245 just while the screen was off. Immediately my battery stopped dropping off. I finished the rest of the day barely losing any. Today I've been running it moderately all day. As of right now I've been off the charger for 15 hours 39 minutes, with 1 hour and 36 minutes of display time on and 45 minutes worth of calls. I'm still sitting here with 53% battery life thinking at this rate I could get another day out of it.
What I'm hoping for is that maybe a few of you would like to setup a setcpu screen off profile of min 245 max 245 and try and duplicate my results. Obviously you would need to be rooted to run this.
Anyway this might be a big help to some of those that are suffering with bad battery drain, if this works across the board. Maybe HTC is running some kind of process in the background or something that clocks the processor up. Or who knows maybe it's just me. lol
By the way I absolutely love this phone more and more each day and if my battery life continues like this I'll be totally satisfied. Thanks to all the devs, and thanks to all of you for your many useful contributions I've encountered here over the past year. Happy Androiding.
Note: Remember this test is mainly setup to improve standby time while the screen is off, it won't improve your battery life if you are playing with your phone all day .
It may be helpful for those who are reading this thread to list a few details about what setup your running while using this tweak like,
SetCPU Profiles:
Rooted (Y/N):
Rom/kernel:
Screen Brightness setting:
3G/4G area:
Time off charger:
Noticeable improvement yes/no:
Edit: Screenshot is from the next morning after leaving it off charger for over a day. I only lost 6% overnight.
cliff notes:
if you're rooted, download setcpu
create a profile for when the screen is off
set cpu to 246 mhz
battery life should be better :cool:
Reactions: matai789
I really don't get this battery
It's been unplugged for 3.5 hours today and I'm at 32%. On WiFi this morning because for some reason since last weekend I don't get 4G at my house anymore. A couple of phone calls, a few texts, checked a few emails and facebook. No other browsing or other stuff. Only widget running is Accuweather.
Other times I can get 8+ hours before I hit the 30% range. Maybe it's time to ask for another battery? My use is pretty consistent. No huge fluctuations in use.
Also, tried Juice Defender Beta yesterday and it seemed to suck the life out of the battery. I disabled it. Does it still run hidden in the background?
I mentioned earlier that the app Green Power works wonderful on the Thunderbolt. I never had any success with Juicedefender on any phone, and I had purchased UltimateJuice with it! It kept closing without me knowing. I rooted my Thunderbolt and got rid of the bloatware. Loving my phone now. Getting at least a 20% battery improvement! Because of the improvement though I find myself having to charge my battery in the middle of the afternoon because it doesn't run completely down until halfway through the next day! Waiting for CyanogenMod. Thanks all to this site, and the boys over at X*A get a little credit too.
so after reading enfuego 360 s response from HTC. To translate HTC basicly told him if you shut off the phone it wont drain your battery...
My battery life is getting worse. Bought my phone on the 18th and today I didnt even touch it other than to take it off the charger at 10AM, by 5PM I was at 15% with everything turned off and it remained in my holster all day...
So much for battery life getting better over time.
My Android experience has been really frustrating, I jumped full in with a ton of enthusiasm and bought a Thunderbolt and a WiFi Xoom. It just seems like I forgot one thing, to make sure there was any water in the pool before I dove in...
Dont feel too bad about the Xoom because I can still take it back, and Im sure it Honeycomb will be worth revisiting in 6 months or so.
The Thunderbolt however didnt start getting HORRIBLE battery life until day 14 and Im stuck with it now.
Hi folks, this isn't directed at anyone in particular, but for anyone having poor battery life I recommend posting information about your battery use. People reading this forum may point out something that can help you. I'll post mine as an example, my phone has only been unplugged for about 15 minutes and may not look the same stat wise after running for 10 hours.
You can get to this info by going through Menu -> Settings -> About Phone -> Battery -> Battery use.
15m 43s unplugged
Display 85%
Android System 4%
Cell Standby 3%
Gmail 2%
Tapatalk 2%
SwiftKey 2%
Android OS 2%
What you should look for is any app that is at a high percentage that is inconsistent with your use. E.g. you have a score board app you have not opened but it is 45% of your battery use.
Regards,
Lenny
Sent from my ADR6400L using Tapatalk
Reactions: matai789
Flash the DAS BAMF ROM and the 1.3.2 kernel. Use the smartass governor in setCPU. That will SOLVE your battery problems.
I've been off charge now for almost two hours and only down to 97% battery.
Normally by this time I am under 90%.
Simply amazing.
I have really struggled with my battery life. I tried almost everything except rooting. I would look at my battery at 11:00 AM and it would be at 30% with virtually no use. I was getting very angry. My wife has a TBolt and was getting SUBSTANTIALLY better batter life. Hmmm. She had gotten a replacement phone for an issure unrelated to the battery. (speakerphone issues) I decided to swap the new battery that came in the replacement phone with my battery. My battery life tripled. I'm getting 12 hours of moderate use. Nothing different except swapping one OEM battery for another. I have to believe some of these batteries are defective. Time to step up HTC. You gave us crap batteries.
today I was at a class for work and I was in a 4g area but my signal was only 1 bar and my battery was full at 7:00am and down to 15% at 4:00 pm it definety lasts longer in a 3g area (my home) with the same amount of use. So I can see why those that live in 4g areas may be seeing less than average battery live. with the stock battery I hope HTC gets a firmware update to better control battery live.
Simply amazing.
I keep reading similar reports.
What's your usage like?
I got up to page 10 and I haven't seen mention of it yet. Is anyone using the slim (slightly) extended battery?
Also, would battery performance be better with an after market battery.
Also, also, there is now a 4G toggle on the market (in case no one else has mentioned it). It's called LTE onoff.
Do you have a link to this slim/slightly extended battery?
If it's the Seidio 1600 or 1700...it's no better than the factory.
But if you're talking about a different battery...we're all ears..:)
The LTE on/off is just a pretty interface instead of digging into the menu by the # key and numbers.
It's a great tool...nothing fancy or anything.
It is the Seidio battery. I was hoping for miracles out of those 200 extra mah's.
Oh well. To tell you the truth the battery has been performing pretty well since I turned the brightness down to 25.
How important is using the OEM charger? Im currently using a Motorola wall charger and the only difference is the output, 5V @ 850mA. The HTC charger is 5V @ 1A
Installed the app called 4G OnOff to turn off 4G when I'm not using it. FYI I'm in a constant 4G area. I had decent battery with 4G on all the time, but with 4G on only during heavy web browsing or FBing, I got 16 hours of heavy usage.
martacarl
