[Tool] Root 2.11.605.9 and .19, no downgrade or data wipe!
Looks like I got my phone mounted to my PC finally.
Running Skyraider.
Charge only did nothing (unlike before)
Disk Drive works.
How can i unroot this and return to stock incase i neex to take it to vzw to replace it? So its like oit the box?
Link in sig
Sent from my Liquid ICS Thuderbolt
slight issue, i reformatted my computer, installed your drivers, place phone into diag mode ##3424 send, installed those drivers just fine. then went into fastboot to install those drivers and then it finds an unknown device. I ran your drivers file program and it still wont find it. I assume that your tool needs the phone to be in fast boot at some point which is why i place the phone into fastboot before i ran your tool so that i would have the drivers for it pre installed but it wont install them for some reason....
It automatically puts it in fast boot if it needs to
Do i need the drivers for fastboot installed? as my computer see unknown device under universal serial bus under device manager... i have windows 7 ultimate 64bit. I even reformatted and reinstalled windows and the drivers you gave but those drivers dont show they install it just shows nothing... i click on it and dont see anything... i right click and select open but still nothing...
Hmm that's weird, try redownloading driver from here http://db.tt/Z9AGk6W4
Prince08900
