[Tool] Root 2.11.605.9 and .19, no downgrade or data wipe!
Thanks so much for posting detailed instructions. Everything went great for me.
My only suggestion is that you edit the text instructions.
Step 10 is somewhat incomplete and I had to review the video tutorial to find out what to do.
After "-Restarting adb..." you may want to add the following:
Do you want to block OTA Updates? [Y/N]
Enter Y. It keeps you from getting bootlooped.​
Otherwise, totally awesome!
I think I'm going to update it with the release of my thunderbolt tool to where it automatically blocks otas.
Sent from my ADR6400L using Tapatalk 2
I gave up on it last night I'm gonna try again tonight it just sticks at waiting at fastboot forever to get it out of that I just pull the battery i hope that doesn't screw it up
Fast boot drivers installed?
Well it finally worked I guess it's like me and doesn't like windows vista but it worked great on win 7 thanks again for all the help and for making an easy to use tool for is people who aren't so tech savvy
Reactions: trter10-imore
Glad you got it working :)
Everything seemed to go okay but I cant boot into recovery and rom manager still thinks my tbol is unrooted, even though your tool says it is s-off
Got it figured out! Rooted and rom'd! Thanks for the tool/guide.
But I do have one last issue, ever since I rooted...my PC wont detect my phone like it used to? Hmm. Ideas?
Sweet!
Maybe try disabling and re-enabling USB debugging.
i can't get to the recover selction after hboot update it is s-off but root check says i don't have root access
my phone soes an update when those files are being seached then it says press power to reboot can someone please help?
Prince08900
