touch input problem
IFESI
i have a problem with my touch input....it always displays this message ''''.the application touch input (proces com.htc.android.htcime ) has stopped working unexpectedly please try again'''' what do i do to fix it please
Hello and welcome to Android Forums - thanks for joining the community. ;)
This is usually caused by a corrupt or an incompatible application. Prior to this unexpected error message started - if you can find the last installed app and uninstall it, then you might get rid of that annoying force close issue.
It would also be a good idea to check in with the other users of your device, to see what other solution they might have for this problem.
Good luck. See ya around the forums.
KidColoringPage
