Tracfone not Total wireless?
Double Tap
519
10
18
I just purchased the 3a to replace my Moto G5 plus. I have a Total Wireless Sim card and when I go to network it says Tracfone, why?
Hi do Tracphone and Total use the same cellular towers? Are they both mvno services using the same basic network.
I did a quick search and it appears you are correct. They are essentially the same company. I'm sure they would then use the same towers.
musictheory
