(tvalls kernel) UPDATED 6-6-2012
A logcat would help with force close issues. Other than that I can't offer much help.
try the vm version of my kernel if you're getting swapped buttons.
Re: (tvalls kernel and rom) UPDATED 6-6-2012
been using the Rom for 12 hrs now some issues that i have seen but is this flashed from drews CWMT recovery The Backside updater FC's the goomba theme in theme chooser doesn't completely apply Camera FC's Camcorder FC's and then there is some things in the power menu that dont work on our phone and can be removed That's all i can really report on so its a nice Rom so far also if we could get a link to gapps
You should be able to use the gapps from thekravens cm7. I will reinstall this evening and try to get a logcat for you
Sent from my LG-LS670 using Tapatalk 2
I just flashed it plus my sprint kernel on my ov to test. I didn't see any of those issues so I'm assuming you are using the included kernel and its having issues.
I avoid linking to gapps as much as possible. Find them somewhere like the cyanogenmod wiki or at goo.im. I'll provide a link once I make a thread for the rom.
OK, I'm on thekravens CM7.2RC1. Buttons are swapped and bluetooth "disconnects". That isn't really descriptive.... The bluetooth stays connected, but then drops media and phone, yet stays connected. This happens after bluetooth is used once.
I'm currently on a different kernel without the bluetooth issues (BobZhome_kernel33_gcc452).
STOCK BASED ROMS ONLY!!!!!!!!
i did not make this if you have any thanks it goes to tvall
all i did was post it here there will be updates most likely. i have only tested on reborn rom might only work on froyo rom but test and tell me what you find out.
THANKS TVALL
it works on reborn test on others and let me know what roms it works with
list of roms:
Reborn
test and let me know
download link
https://www.dropbox.com/s/28y3ss27ux1d9h4/tvall_kernel_vsprint0.3.4.zip
This thread is for testing purposes of the kernel
Source code
In second post
Tvalls sprint kernel
787 mhz
8gb
amphetimines
EDIT: GLITCH POST
Sent from futuristic optimus s
gaganprasad
