Twitter notification sound?
Twitter fixed this issue so everyone should be able to change their notification sound within the app itself.
does anyone use twitter lite?
do you have sound in notifications?
I don't, I searched everywhere in settings and I couldn't find where to set it up
so, I used megasound
I signed up to this forum just to tell you guys there is actually a solution to this issue.
just search MegaSound on playstore. is an app who will allow you to setup custom notifications sounds for each app. chose twitter, put your mp3/wav/anything and..voila.
works like a charm for me
you're welcome :)
so, I switched to original twitter app and I found out that the problem with notifications is still there,
I mean sometimes there are notifications without sound!
I tried with latest version, I switched to 6.22 I was using before, same result,
does anyone know of a version that doesn't have this problem?
slackingfred
