UCKJ1 2.3.5 leak
Ok-I installed the 2.3.5 and it really was as easy as it sounds (Thanks for posting the leak and the clear instructions.)...but I could not figure out how to do the first step -the factory reset. As warned, the tethering manager force closes all the time.
I have build #1101 and tried to follow the instructions on the restore factory thread on this site but now I'm lost. Any ideas?
Thanks for your help.
Usually when people refer to a Factory reset/wipe they are referring to the option in Recovery Mode. Boot into Recovery and select FACTORY RESET.
so if im on UCKJ1 can some one tell me how to go to the higher builds and where to place the files in ODIN and which ODIN version to use.. please private message me my phone build is 1012
nov1971
