UDP IPTV Play Working in Android Kit Kat But not working in Android Lollipop and above
khawaja Abdur
Hi,
I am having issue in playing IPTV provided by local ISP on android device having android lollipop and Above.
In Android Kit Kat there is no issue.
It mostly happens with UDP/RDP IPTV Streams, HTTP Works fine.
Workaround getting it work is to run UDP-TO-HTTP Proxy on some PC and configure IPTV application to use that proxy.
But it bothers me a lot why IPTV UDP feature is removed from Android Lollipop and above.
What is logical reason behind it? Or is there any simple solution that IPTV works without UDP Proxy as it makes me keep running my PC with UDP Proxy Application.
Thanks
serpdad
