Unbrick a hard bricked Samsung Galaxy SIII Sprint/ Virgin Mobile
Hi greenshortskid,
Thanks you so much. You have been very helpful and I learned a lot from you.
I originally had my Samsung S3 Galaxy (SPH-L710) rooted until sprint/samsung pushed the 4.3 upgrade. All was working fine except it was not rooted anymore.
I rooted again successfully just to put the clean factory software back on (so I can reset the binary count). I successfully put the stock image (KIES_HOME_L710VPALEN_L710SPRALEN_618049_REV03_user_low_ship.tar.md5) back on after resetting the binary count through Triangle away. Then it was doing the SPRINT or Samsung updates over the air when it restarted 3-4 times. Last time, it didn't come back from the restart.
I am not able to go into download mode anymore. Ordered a JIG through E-bay but it didn't help. Used it on my other S3 phone and it works. I went to Radio Shack and purchased 100K ohms, 1/4 Watts, 5% Tolerance resistors. When I checked with the meter, it was a lot less ohms. So I added 5 x 1k Ohms with the existing 3 x 100k Ohms resistors to make it right in the middle of 300k-301k Ohms, still no luck.
I even purchased a 16GB Class 10 Micro SD card and burned a image with Win32DiskImager for debrick_sph_l710.img, but my phone still didn't respond or booted through it.
When I plug in my phone to computer, it shows as “QHSUSB_DLOAD “ for which I downloaded QHSUSB_Drivers_(x64) drivers and it showed up on COM6 as “Qualcomm HS-USB QDLoader 9008”. So I tried to load the Sprint 4.3 Stock Image (L710VPUCMK3_L710SPRCMK3_L710VPUCMK3_HOME.tar.md5) using Odin but it didn't complete unless i need to let it sit for way longer than normal. I let it sit for a good 30 minutes but it was stopping at "??something?? Connection" - don't recall exactly.
I noticed when I take the battery out, hold down the power down button, put the battery back in and plug it into the charger, i see the red power light comes on for about a 30 seconds or so and then it goes off. It used to be always blue when working (on the front of the phone).
I have less than a month to be eligible for an upgrade and little more three months under contract. Don't want to pay Sprint $75 to look at the phone and most probably going with S5 when it comes out and not sure with Sprint or some other provider. In other words, don't want to spend money on this at this time. Could you please please offer any help? Greatly appreciated in advance,
Sal
Re: Unbrick a hard bricked Samsung Galaxy S3 Sprint/ Virgin Mobile
Do i have to use a 16 gig sd card? I had philz recovery on my virgin sg3(sph-l710) i did the clean system to install new rom and i tried flashing a rom but it gave me status 7 so i tried many other roms all for my model and it kept saying status 7 so i tried rebooting and it got stuck on the samsung galaxy s 3 screen, since then ive tried various methods to unbrick i tried with a stock rom using odin and it still wouldnt flash. i think im just soft bricked because i can still navigate to both recovery and download modes. Wondering if i can do this with the 8 gb sd card i already have or if i should just jtag my phone. Please help, i only had the phone forr like 2 weeks and i feel like an ***** T_T any help would be greatly appreciated :) Also i cannot get phone to boot so i cant download triangle away to reset my custom binary count :(
my phone is not coming to download mode...nothing is showing on screen....what i will do?:-\:'(:'(:'(:'(:'(:'(:'( not even vibrating
plz help me plz
Hi greenshortskid,
Sal
I am also having same problem..please help me......i am from bangladesh..i went to service center of bangladesh and they said they cannot repair it have to replir from other country....please help me how to fix it..please....is jtag is my last hope???? And can it fix?
I have a spint SPH-L710 that was running a n MK stock4.1.2 rom rooted with Kies I wondered if someone could provide the files and steps to using the debrick image. The video that was originally telling how won't play anymore.I know there is one on XDA but it uses linix and I know nothing about using it.
hi dear
i have bricked my phone samsung s3 gt i9300
how can i unbrick my phone
please could u help me ..
Thanks & Regards
I'm having the same problem after installing a custom ROM. Were you ever able to fix it?
Re: Unbrick a hard bricked Samsung Galaxy grand quatto
my samsung galaxy grand quattro is hard bricked, how to fix this problem
pratikkumarBB
