- Feb 6, 2017
- 97,745
- 13,808
- 113
Long press it and tap info go to storage and clear data,cache and force stop....repeat if necessaryThe voicemail app is not working for me on my unlocked note 10+ just keeps saying checking account. Any ideas?
Hey friends, does Samsung have a native VVM app? I have the unlocked version on t-mobile but Samsung chat said I had to use the carrier app. Any ideas?
That's what I keep reading. Maybe someone has a link to download myself? Anyone? LolOn my unlocked Note 10+, I have a VVM app called Voicemail. The app details show that it was downloaded from the Galazy play store. A search in the Galaxy Store doesn't find it. I think that it was installed when I got the phone from Samsung. This app works with my AT&T account.
You usually get the option after someone leaves you a voicemailAT&T just did something, just downloaded.![]()
I thought that too. I've had several voicemail left and I have to call into my VM.You usually get the option after someone leaves you a voicemail
Can you give me an idea of how to do this. Been on an iPhone for the last 5 years so I don't know much about android. Did try one last year but it had a VVM installed already.If you clear your data and force stop your voicemail then get a message do you get this message ?
I should say that I am too unlocked but using the Verizon network
I only seem to be getting Voicemails
You check in Samsung play store under my settings then updates?The only VM is in the phone app.![]()
I do. But when I long press it, it dials into my VM. I'm so use to iPhone with having the VVM. I just thought Samsung had this figured out.When you open your dialer do you have anything under the number 1 ?
Yeah nothing there.You check in Samsung play store under my settings then updates?
Try in the app drawer , 3 dots upper right corner tap and go to GALAXY essential scroll through the listYeah nothing there.
Yeah just checked and nothing there either. Do you think of I remove my Sim card it'd show up? If not I guess I'm out of luck.Try in the app drawer , 3 dots upper right corner tap and go to GALAXY essential scroll through the list
