Unlocked note 9 pie beta live
well it isnt text messages or phone calls. it's pretty much just 3rd party apps
I'm sure you checked the sounds menu and see of all volumes are up and didn't schedule mute in sounds settings otherwise if you haven't tried clear cache in recovery.
nah notifications are turned up and I don't mess with scheduling haha. not sure what's going on. been the same way on both of my notes with every beta I've installed.
Gotcha maybe it's a glitch and be fixed for you in next beta.
Not having this issue but hopefully if it is a bug they will address it in the next Beta release. Did you by any chance report that in the Members app? If not, I suggest you do as Samsung does read all those issues and bugs and they make note of them as well.
I forgot to mention that to him , thanks.
unfortunately im not on an unlocked device. so I am not actually in the beta officially. I am in it unofficially though haha
Did you download the beta 2 firmware? Unofficially lol
Yea I did im currently installing again. I didn't like the latest one from dec 20th it is a carrier version and is pretty unstable. so im moving back to the unlocked beta
Gotcha, I'm on the unlocked beta pretty stable
what about call logs, and blocked numbers going missing. anyone experiencing that? I wish I could see some of the bugs being reported lol
Not experiencing that
Only ones seeing bug report being reported is Samsung.
I guess you have good luck. I'd like to report some bugs unfortunately I'm not going to go buy and unlocked phone and hope to get into the beta though Haha.
I'm on another release now. kernal build from the 18th. released on their firmware site in the 22nd.
the last one I was on had the same volume bug
call log bug
and wouldn't save my watch after power off.
call log bug
The only issue I have is Samsung plus app crashes and sometimes slide left to bixby freezes..
Last year when I was on the beta had more issues but smooth going for me this year.
call log bug
Not sure if the issues you are having are due to the version being side loaded instead if the official one from Samsung. Definitelt not having that issue as well.
Could be. I install using Odin. Then install updates directly from my sdcard in the phone. the notifications I can deal with. phone logs not so much.
opegamani
