Unrevoked Evo having SD Card problems
RyboCollier
6
Hello,
Last night I rooted my phone using the unrevoked method and I installed fresh 0.1. I had an issue last night where my phone wouldn't see the SD card.
Has this issue been resolved with the newer versions of the fresh rom? How do I get this update applied so that I don't have any issues with my phone seeing my sd card? I've only had enough time to get 0.1 installed and I would like to have 0.3 up and running by tonight.
Thanks!
Hello,
Thanks!
Sounds like you have the Old Rom version...
Update and you should be good
To be honest i've never heard of it. Im new to Android and new to rooting. I've read that Fresh is a good rom to choose so I went with it. What are some benefits of Bugless over Fresh?
I can agree with that...
I was reading the "EVO-NonSense(AOSP Elements)" Has JIT enabled...
Is this a Froyo Build like Evolution v8?
Or is it just a 2.1 Rom...
its a 2.1 rom with a jerry rigged JIT. you get a 2-4 MFLOPs increase on benchmark.
I've been reading some threads throughout several android forums and it seems that there is no fix for the sd card issue with the Fresh roms. If I'm wrong can someone please correct me, if not I'll be going back to the stock rom.
jochu
