Update help!!!
I know what it is but I can only download 1.0.4 I can only get 1.1.0 throught goo manager. And I update gapps cause it tells me to once a week.
Sent from my HTCONE using Tapatalk 4 Beta
@pergerson6 I'm trying to flash the viper rom 1.1.0 and I can't do it with just recovery nor goo manager. There's gotta be something I'm doing wrong.
Titanium backup, reboot into cwm or twrp, nandroid, superwipe, factory reset, wipe cache/dalvik, flash Rom! Are you on Sprint?,
Yes I am btw I did all of that so many times. I just think that twrp or goo are both refusing the update. Maybe due to the download path? but sadly the path goes to the goo folder. But once its done downloading its not in the goo manager folder like you think it would be. That's maybe the reason why I cant flash through goo manager.
Try another recovery
How do I change the recovery?
Copy recovery image to Adb folder, and in the folder rename to recovery. Boot phone into bootloader and plug to usb. Run phone in usb fastboot mode. In the Adb folder open a command prompt window and type fastboot flash recovery recovery.img
So it's the same process as I did with twrp just a different name. Okay thanks:-)
Just make sure it's the correct recovery image and you should be fine. I still use old reliable cwm 6.0.3.1
I was thinking about the touch enabled cwm recovery. Any feed back about that custom recovery system?
I use the touch version. I didn't like philz touch cwm 6.0.3.4 because I thought it had too many options.
So if you'd had to rate twrp and cwm you'd pick cwm? Just trying to figure out the best recovery. Cause twrp won't allow me to update my main rom.
I never liked twrp.
I never liked twrp.
Yeah I'm starting to regret it. I have nothing but problems trying to update viper rom to 1.1.0 and I'm stuck on 1.0.4 but I like the sense platform so I been sticking with this rom but once in a while I'll pop to CM 10.1 and do an update and ride with it for a few days.
I've been on ecliptic One since 7/23! I love the speed of odex using elementalX 0.6. This is the best set up I've used for my phone. The reason I stayed on 6.0.3.1 is because the newer versions wont let me run the superwipe script.
Any good sence roms the are De bloated and fast?
I use the Rom cleaner De sense script on every Rom I have used. I have nova prime which imo is the best launcher ever made.
Can you explain superscript and how I can flash a kernal with a rom separately?
probang
