Update to 4.4.4 for AT&T
I got mine last night for the S5 active. If I hold the home button, Google Now comes up. No other issues yet.
I just called AT&T, and they told me that they recommended me not updating right now because they had a message on the computer saying it was causing people some people to have issues using their data
Sent from my Galaxy S5 via Tapatalk
That's odd, I've been on it since the day they rolled it out and I'm not using any extra data... usually use very little data since I'm on wifi so frequently, and I still have very little usage. Love to see my extra data rolling over though!
The only issue I had was fixed with a restart. Everything else is fine.
The main problem I'm having since mine updated Saturday night is the home button keeps opening Google Now. It's driving me insane. Plus my notification sounds don't work half the time and other odd issues keep happening.
The Google now was my issue. Restart the phone. That should fix it.
Restarted here and also pulled battery and cleared cache. It still happens to me. About every 3rd or 4th time I hit my home button this shiznit pops up.
Boom! From My S5
Guy's. ...I had the same problem with home button, I had Google launcher and nova launcher installed but when I deleted Google launcher it took care of the problem with home button and restart the phone after delete the launcher
SAMSUNG S5
I'm also having the Google Now issue. Every time I pressed, not held, the home button the damn Google Now screen would pop up. I haven't had it happen since I rebooted the phone, but others claim that it still returns.
Where the hell is our Lollipop update?!
Looks like ATT proivded multiple options to enable/disable data option. Now when I select data usage option from settings, it shows two empty lines. Each one brings up option to select Standard/4G for local and international.
I've rebooted, pulled battery for 30 minutes, manually switched from TouchWiz to TouchWiz Easy and back, booted into recovery mode and wiped cache partition. Works for a while then Google takes over Home button again!
I finally figured out my "notification" problem isn't notifications but the fact that the messenger app doesn't have sounds or vibrate IN THE APP. Am I insane and just THINK that before the update it used to have a nice little sound and vibration when I sent or received a message while I actually had the message open? I can't find anything online about in-app messenger sounds or sent/received sounds. Call me crazy but I really like to have a sound when I am in a conversation in case I sit my phone down and don't turn it off for the 3 minutes my screen timeout is set for. Is there a better messenger app that includes sounds when you send and receive texts?
I'm not having the problem with Google as much as I am with the Wi-Fi & Internet connection. Since the 4.4.4, I've had problems connecting to the Wi-Fi.
angelag5098
