USB C Cables.
Went to Target. It was pricey. I bought a car charger which includes the usb-c in each end. $44.99. Like I said pricey. But it was 3.0 amps all black and a descent size cable.
I recently bought a 6.6 ft iOrange-E cable. I also bought a 10k mAh power pack so I need a 1ft cable as well.
I have two Aukey USB C cables. One of them came free with the USB 3.0 Slim Car Charger that I bought.
I got the 6.6 ft iOrange-E braided cable (and I'm kinda regretting getting the 6.6ft. I should've gone with a 4 or 5 ft cable) and an Anker 1 ft. The stock cable went to my car. I also got an Anker dual outlet.
I'm looking for a charger as well that is pretty inexpensive and not too long. I just want to use it in my car for my charger so a short wire is all I need. Most of the ones I've seen are 6 feet, I'm looking for one maybe 3 feet or so. Also I usually get stuff from Amazon so if anyone could recommend one from there that would be cool.
This is what I'm using now.
https://www.amazon.com/gp/aw/d/B01K...ag=hawk-future-20&ascsubtag=UUacUvbUpU5667635
When I was still using micro-USB, Volutz was the only brand I used or recommended because they were the most durable cables I've found (and they just looked nice). I now have their 3 ft USB C cable and it's been working great so far on multiple chargers. I can't really say how well these will last yet, but I would expect them to be just as high of quality.
https://www.amazon.com/gp/aw/d/B01K...ag=hawk-future-20&ascsubtag=UUacUvbUpU5671045
I've never seen any with this material before. You'd recommend this one over the usual ones? Since it's a pack of two apparently that's not a bad price. I'm just curious about the durability.
Edit: The reviews seem pretty good, as long as it works with this phone then I'll probably just get it.
So far, so good on durability. I just haven't had them long enough to fully judge them. I do know they honor their 2 year warranty rather well. I had to claim one with a micro-USB cable that got a weak tooth, and it was fairly quick and easy getting a replacement.
I'll also add that these are very flexible for being a braided cable. The micro-USB versions were always a little stiff out of the box and would get more flexible over time.
customer28
