USB-C cables
It shows up as Prime for me.
I currently do not have Prime so it must show up differently than when you have Prime. I was not aware of that. I am always learning something newツ
Thank you for posting, I appreciate it!
You would not need an adapter.
Thanks.
All this USB C is confusing to this old gal. 😊
Just want to be sure I get the right charger and cable for this phone, of good quality.
Wish I could find shorter cable, and say 1.5 for car.
I learned something new too. I always figured it would show which was Prime no matter what.
This may not be right place to ask my question, if it's not I apologize.
Can I safely use the adapter in my car charger that is not for s8+, I realize it won't be fast charger, but just want to use if needed till I get fast charger.
I just don't want to use it if it might damage my phone.
What guys you are buying as to have in car type C cable? I don't need any chargers since I have it from my old edge 7 but I need good quality type C cable to use with existing charger in the car and work. I can use adapter that came with the phone at work but still need minimum one more fast charging cable for my car.
Thank you
I bought Aukey USB 3.0 to USB C charging cables I ask about in previous post.
Can I safely use one of the cables in my wall charger thst came with my phone?
****I went ahead and tried it, it shows fast charging.
Hi nonie, as long as it says it is fast charging it is working as it should and it will be just fineツ
Gergo207
