UXToolkit HTC One XL (AT&T)
Did this help you succeed? Just so I can understand you guys :)
  • Total voters
Status
Not open for further replies.
Re: **OMG NOW WITH VIDEO!** root,bootloader unlock,s-off at&t htc one x on 3.18 update!
So why does it say relocked? And why are you using Cmd if you installed a recovery. Your CID should be 11111111. This means you bootloader is not unlocked
I had to relock it when I was trying to downgrade the hboot. I can easily unlock it using the unlock_key.bin I have. I was following these instructions on this forum here (2nd post): [Q] Need help upgrading hboot | HTC One X > XDA
Do you have the recovery installed? Can you access it at all?
Yes I can access the recovery. It's perfect. Is there another way to downgrade the hboot besides through cmd you know of? I need either 1.39 or 1.72. Ok, I think I realized I need to have s-off in order to downgrade. I'll get back to you later tonight. Fingers crossed everything works out.
Personally, I think you should slow down a bit and comprehend exactly what you are doing. So do I. What rom are you trying to install? You should of stayed on hboot 2.14 because there are plenty of benefits. S off can be accomplished with the link I posted above. There are even stock jellybean roms that require hboot 2.14 as well.
Ur right man. I found out this is actually an htc one XL I have not just the one x. I finally got s-off and I'm about to flash a viper rom specific for the XL. Thanks for all the help and time you put in to working on this tool and helping me out!! It had been a while since I last had rooted phones. This was back on the old Mytouch 3G when I last did a root a couple years ago haha. But it all finally came back.
Dont thank me, thank the developer! And ViperXL is great! I would flash the beastmode kernel (3.5 to be exact), set the phone to the "powersave" mode at 1ghz and enjoy the crazy battery life! I have ViperXL right now with that kernel and I get like 2 days of battery life. (although it may differ for you depending on your usage)
What hboot are you running?
Re: **now with pics/proof** root,bootloader unlock,s-off at&t htc one x on 3.18 update!
Hi, So Ive followed all the intruction in the right side of the toolkit, and have succesfully unlocked my bootloader. now when i try to flash twrp, nothing happens. My att htc one x in bootlader, it says fatboot usb and unlocked on it. i tried copying the twrp to my desktop and selecting it as my own recovery but it come up with an error in the first command prompt popup saying device not found. it was being recognized before i unlocked bootloader, did i do something wrong?
Ok I will help you. Let me get to my pc and I'll assist you from there.
Sent from my HTC One XL using AC Forums mobile app
I updated the guide, so take a look now.
is it necessary to downgrade your hboot? or is that an added step due to having a different version?
haha nvm should of read that last post
Downgrading hboot is not necessary. You should have hboot version 2.14
Im about to do this now hoping everything goes well, so I should follow the written instructions , the video may be outdated?
Nope either one is fine, the info on the video is the same, I just simplified the forum a little bit. The forum instructions should be sufficient. If you run into any trouble, just contact me. Just follow it word for word and step by step and you should be fine.
Let me know how it goes!
Okay, trying to unlock the bootloader and I get stuck when the device reboots into fastboot. Windows says the device was not recognized as it malfunctioned or something. I have the drivers installed so I don't know why this is happening. Please help =!
No go still can't download supersu, I'd Google it but I don't want to get the wrong version
Ok I will update with more links. Do you have the toolkit?
Status
elowen89
