V20 Hints and Tips
I am running Nova launcher on my phone and I had to go into the settings within the app and turn on the double tap function to wake up and lock the phone. Hopes this helps.
To capture photos from video, enable "screen shot" button on video player. It's in the settings while the video player is open.
After you capture all the photos you want from a video, they'll show up in your album sideways. In settings in the screen shot folder with all the photos, you can choose to rotate them all at once instead of one by one.
I did this but it tells me I have to use PIN when it wakes up to unlock the phone and that the finger print scanner isnt good enough. Something about phone adminstrator which I had to enable to let Nova lock the screen.
You can adjust the DPI/scaling of the entire display. The default is a bit to large IMO and looks much better on the lower setting. Settings>Display>Display Size.
Here are a few before and after comparisons.
Screenshot_2016-11-01-18-30-49.jpgScreenshot_2016-11-01-18-30-12.jpgScreenshot_2016-11-01-18-30-39.jpgScreenshot_2016-11-01-18-30-21.jpg
yeah, I wanted to try it for a couple of days.. and I got used to it, but I just switched it back to normal (with an app drawer)
I tried to find the app drawer on my own when i got this phone yesterday but had to do a search to find it. Prefer the home screen with the app drawer.
One thing I LOVE is last night I discovered the little crop tool-works almost like the S Pen did. I wish the S7 Edge had this feature.
I am probably going to try out Nova Launcher on this phone I was using it on the S7 Edge
*sigh*
For some stupid reason LG has not added the AT&T (LG-H910) model as a supported model for the Home Theme+ themes. So when I open the LG SmartWorld app on my V20 almost none of the new themes show up, and when I go to the menu, the customize section dose not have "Home Theme+". I e-mailed the SmartWorld support address about it. They asked me to uninstall and re-install SmartWorld. Of course that did not change anything. They said if it didn't to reply with more info and screenshots. Hopefully I can actually get this sorted.
Okay I'll be the one to ask for the dumb question how are you getting cats
Most likely having way too much time on my hands. Lol.
But seriously, are you asking how I got so many or how to activate the Easter egg in the first place?
Ertiotka
