Verizon G2 CM12 Problems
AKFL3TCH3R
602
So I was trying to update the software of my G2 running CM12. Ever since the update, it has been stuck in bootloop endlessly. I can't get ADB to do anything either. Can't go to any download mode or what ever anymore. Anyone have any idea what to do? I can't get to TWRP..
Did you install the correct version CM12 made specifically for your device? If there's a utility to restore the G2 to factory firmware then you need use that to restore. Let us know if you are able to restore it.
jacob351
