I received the OTA 4.4.2 update earlier this week, and now the bluetooth voice dialer has gone full retarded. If say "call Susan mobile", it responds, "did you say call Susan work mobile". Of course, I say no, and no matter what combination of words I use it never give me the correct option. If I answer yes at any of the suggested options, it invariably responds "no entry, try again", because, of course, there is not "work mobile" entry. I never had this problem prior to the update. The only work-around that works is storing the number is a speed dial number and using "speed dial 2" as a voice command, and it will successfully dial that speed dial number. But, of course, I can't put everybody in my contacts list into a speed dial number, and even if I could, I wouldn't e able to remember everyone's speed dial number.
Has anyone else had this issue? Does anyone know of any solutions? It's maddeningly annoying, especially since I haven't seen any major improvements with the update, making it unnecessary, in my opinion. All it did was break my voice dialing. Help!
