Verizon Note 4 update
Camera shutter is different, and smooth motion can be set as default. Awesome.
Sent from my glorious note 4.
It looks like they also added bloatware (cookie jam and Panda pop) to the install.
Some coupon trash too
More to disable I guess. I just feel bad for the people who don't realize this crap is being added and taking up space and resources on their device.
Other than that, I like the way Samsung implemented Lollipop. So far so good.
First update brought me back down to 4.4.4
Everything looks good so far. Took a long time for Google play services to update but it finally did. I'll see how the battery performs and if need be a factory reset will happen.
Do you really have to factory reset after update?
No. But if you are having issues after the update it's not a bad idea.
I fully downloaded it. It's not bad at all. I didn't have to do a factory reset, not yet anyway. The update was a major battery drain and the device was extremely hot afterwards. The phone is much faster and sharper colors and the new notification bar is going to take some getting used to.
Same here. I downloaded and installed the update on my Note 4 and my wifes. It drained a good bit of battery and was very hot after but now everything seems to be running smoothly. I was thinking I would have to factory reset it but so far everything is good to go.
My wife's phone kept promting an error on Google Play Services but after a couple of resets I was able to update the app and it doesn't come up anymore.
Loving the update
I had the Google Play Services thing too. I think it just takes time. Mine resolved while I was searching the internet to find a solution. I did not even get around to rebooting.
dmflowsjalallodhi
