Verizon Note 5: Works with Android Auto
Phil Nickinson
Android Central Editor Emeritus
Apr 21, 2009
4,506
3,181
Just FYI ... I got Verizon's Note 5 to connect to Android Auto. Had to change the connection type to MTP first, and then tell the phone to ignore Verizon's stupid driving app, but then everything worked fine.
I just had the 4100nex installed yesterday and purchased the Verizon Note 5. Updated the firmware on the radio and followed your instructions, still no luck. Keep getting the message "incompatible USB". Android Auto software is installed and phone is completely updated and radio is set for "others" and USB2. Any ideas what can be the case?
You changed the connection over to MTP?
