Verizon- pie update?
Just checked AT&T again... still no CSAA to CSB3 yet!
Congrats to you Verizon folks who have been FAR BEYOND patient!!! It finally came! AND, to the "Unlocked" Folks as well!!!
I'm in scal for the update an hour ago. So far so good.
I upgraded to CSAA previously.
My Software still says N960USQU1ARL1 and the baseband is CSAA.
I downloaded the CSB3, renamed it to update yet it won't load. Fails every time I try to load it from recovery from the root of my SD.
Downloaded it again incase it was corrupt. Same thing.
Ideas?
Ideas?
Update.zip name or leave it alone and dont rename it ...try both
Thanks. I'm glad it worked out too😜 just surgery, no chemo or radiation ❤️❤️. If I can do that, certainly VZW can push an update!!
It simply won't allow me to update via sd from CSAA to CSB3. Do I need to factory reset and wipe and start all over?
I did. It will let me install the CSAA again but it still says baseband is CSAA and software is ARL1. It won't let me go to CSB3 either with the original file name of renaming it update.zip
I sideloaded the at&t pie update to my Verizon note 9 a few days ago it says I'm on N960USQU1CSA7 is there anything I need to do at this point to be able to receive Verizon updates?
Can you screen shot your software info?
abhifineproducts
