Verizon Pixel XL In Hand
Dear Sir
thanks for your information,. I have a question I couldnt find the answer anywhere.
guys, I am going to buy a pixel xl from a shop but I can not find out if it is google play version or verizon version.
is there anyway to find it out from serial number? or ?
also he has one opened in the shop, I turned it on, there was nothing about verizon on it, but it seems as there is no verizon sim card, It will not show its software.
the problem is the shop guy, doesnt let me check if I can unlock it's bootloader or not.
I can only see all software versions and also serial numbers...
I will be pleased if you help me in this.
Regards
bijan
Dear Sir
Regards
bijan
In developer options, if oem unlocking is grayed out and can't be changed, then it's verizon model. To access developer options if it's not showing - go to settings, about phone, and click 5 or 7 times on the build number - it will show. Hope this helps
Danielymusic
