Verizon S22 ultra wifi 6 issues
Neal Smith
305
Forgive if this has been asked .
My issue is I keep getting connected without message on my phone. Phone usually connects for a limited time then l get connected without internet. I have Optimum internet service and I've tried going into settings and change to static ip settings..turning off router, changing randomized Mac to phone mac ,changing last 2 numbers on ip address ,date and time to automatic..factory reset... all no go.Any help would be appreciated thanks
Hi Neal hopefully someone can help out that uses WiFi 6 i don't have it unfortunately:(
Do u use a vpn ?
Do u use a vpn ?
I do yes.. I've tried using it with or without. The wifi 6 that I use is my work it never does this at home with the two ssids split. Thanks for reply
The wifi 6 at my job doesn't play nice with the private DNS I have set up on my phone. I have to turn that off before I get to work or my phone won't connect to their wifi ( no issues at home). Do you happen to have the private DNS set up?
Sent from my SM-S908U using Tapatalk
No private dns
I used to have that problem regularly on my home router, but it finally stopped about 2 updates ago. It only happened when I 1st connected after getting home, but it was fine after a reconnection.
gmcbride
