Verizon S6 - - - better experience on Metro PCS or Cricket?
rockitdog23
390
11
18
I have a VZW S6 that is unlocked. I'd like to join either Cricket or Metro PCS (preferably Metro) but am wondering which device will give me the best experience based on network compatibility. Thanks!
Looking to take advantage of Metro PCS and their unlimited data for $60/mo!
Just an FYI, cricket throttles your download speed to 8mbps.. metro does not.. that 8 Mbps is max, not typical speeds.. have read reviews stating most get between 2-6 Mbps download speeds.. I use straight talk and get upwards of 24mbps.. just something to think about..
Also, cricket runs on at&ts network, and metro runs on T-Mobile..
You choose by which carrier - AT&T or TMobile - gives you the best coverage where you need coverage. Fantastic service on the best phone where there's no signal isn't worth 2 cents. There are apps that will show you the various towers around you and what signal strength you're getting from each. (Check the actual places you need signal - at your desk, not on the street in front of the building. Dead spots can be as small as inches in diameter.)
Best experience will differ greatly depending where you live. We can't answer since it may be great for us .. but horrible for your area.
Taylor Bag
