Verizon SIII JB Upgrade to 4.1.2
Thanks for that! I'm running just stock 4.1.1 rooted with CWM recovery, TouchWiz kinda grew on me after bouncing around various ROMS. I guess I'll wait until someone posts the full stock 4.1.2 image to apply this update. Forgot I was rooted last night and almost accepted the OTA update.
Krispy,
Once an image becomes available you should be able to use Mobile ODIN: http://market.android.com/details?id=eu.chainfire.mobileodin.pro to flash the new image and inject root at the same time.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
When we originally got Jellybean, it was annoying that everytime I connected my phone to my laptop just to charge, I would get a popup asking me to install Verizon crapware to "help your Galaxy S3 communicate with your pc." And the popup won't go away until you answer. Annoying, but tolerable. Now since the update, after I say no to installing the crapware, I get the "Program Compatibility Assistant" popping up telling me that the program did not install correctly, and asking me to reinstall.
I don't need this software, anymore than I need to install anything to access a flash drive. I installed it once when Jellybean first came out, but when I saw it was useless to me, I uninstalled it.
Please, just let me charge my phone in peace.
Another thing I just noticed is that you can now grab a picture from an existing video, much like the One X does.
They have stock rooted 4.1.2 over on xda. http://forum.xda-developers.com/showthread.php?t=2178482
Sent from my SCH-I535 using Android Central Forums
I had it available today on my phone but after downloading and rebooting I get an error saying I have unauthorized softward on my phone. I went to Verizon store and they were clueless and just reset phone. I tried again and got the same error but now can not figure out how Verizon reset the phone. I've tried volume up, hold the home key and the power key and let go at vibrate but error still keeps coming up. Any suggestions other than going back to store?
Power off the phone, then hold volume up, home button and power until you see the galaxy s3 logo. You should boot into recovery. Use the volume rocker to select factory reset the use the power key to select it.
Rooted S3 here with stock image/ROM. I used Triangle Away to get rid of my flash count and to preserve the "Device status: Normal." I downloaded the update and it installed using CWM, after it installed it asked two questions, 1) if I wanted to prevent flashing the stock bootloader (I said yes, of course) and 2) if I wanted to maintain root (and again, I said yes). Phone booted up (after a scary 5 seconds of it stuck on the "Samsung Galaxy S3 screen), and it said update failed. However when I went into the status, my phone says its on 4.1.2 and I still have root.
photo burst option is cool. same with sending a long text message where the field expands and you don't need to scroll up to see it. wonder what else is on there....
Got the update today and it appears to have broken streaming music to my Jeep. Phone still works, but it doesn't seem to connect for streaming media. The Jeep where it lists the phones has a spot that has a check for phone, and and x for music. Tried rebinding the phone, but not having any luck so far. So if this is enhanced bluetooth, count me in for a thumbs down.
After the update, my battery is not doing nearly as well. I had the same issue when the Jelly Bean update occurred, so I'm hoping it improves with time. Yesterday I'd go through 40% of my battery in under five hours, without even touching it. When I looked at the usage (no screen shot), I had majority of the battery being burned up by the Android OS, with second biggest culprit being Maps. Again, it was merely sitting by me at the same desk it normally sits at, but burning through battery. Even this AM I burned through 10% with minimal usage after I took it off the charger, in less than 30 minutes. Rebooted it, so let's hope that helps, or it just calms down a bit with time.
I was seeing the same thing but having better luck after 3 or 4 reboots.
Since the update I have been getting increased battery usage! 1 day and 6hr, and still 56% battery. Don't know why.
Have any of you noticed that after this update when you try to move an icon on your screen it just scrolls really fast through the pages and makes it difficult to place the icon on the page that you want it?
Sent from my Samsung GS3 using Tapatalk 2
I've noticed similar behavior with 4.1.1. Don't see it as an issue, just something that takes awhile to get used to. But understand how it can be somewhat difficult at first.
Maybe setting the animations to 1x will help.
--Tapatalk 2 on SGS3.
I was prompted to update my phone as I was walking out the door around midnight on Friday and let it update. Not sure why but I was in a hurry and just clicked okay. What you described is similar to my experience and I was left baffled. Upon restarting I was told the update failed in a pop-up window. Initially looking deeper I was told the update failed with an error code 410. I checked for an OTA update since the update had supposedly failed, was informed there was none, and then went back to check my details listed about the device. My phone shows as completely successfully updated. It's been 3 days without any issues. Go figure.
Is there a way to force the update. My S3 is 2 weeks old and nothing either OTA or via Kies.
Has been a rough week. Woke up last week with phone constantly losing data- kept going into Airplane mode. No phone calls or data would last more than a few seconds. Frustrated and went to Verizon. They swapped Sim and it worked for a few seconds. In car outside store Airplane mode returned, constantly. Went back in and they said it must be one of my apps. Now an app was trying to auto-update when the Airplane mode debacle happened, so I removed that app. Still a problem. (Reminder to not let apps auto-update. If there is a glitch it can be a real problem).
Verizon store was useless to help me find what app, so I restored to factory condition. That solved the Airplane mode problem, but while rebooting phone it mentioned an update. I didn't know it was 4.1.2 Thought it was 4.1.1 Phone was speedier, but that might be because of the 4.1.2 update or because my apps were not restored. My backups failed to restore so I have been manually re-installing all the apps I can remember using. Having to re-authorize email and other accounts. Good thing is I will have less bloat from my own apps I never used, bad thing is remembering which ones I liked and occasionally used. Play store tells me which ones I have purchased IF I scroll to them, not so much with free apps.
Still haven't got everything the way I like it, but am liking some features of 4.1.2 :cool:
By the way, when they authorized my new Sim, they turned off my wife's Sim. She had to go to the Verizon store the same day to fix that.
Later she would get the 4.1.2 update without having to go to factory defaults. She just lost some email for a bit, then it came back.
Ive noticed way better battery stats, usually with hard use I would run down my battery in a few hours, I'd say its almost doubled it now
Edit: after using outside of my house the batter has dropped quite a bit, main culprit wakelock. Not sure what's doing it though because i have twitter and Facebook set at refresh every 4 hours and the main screen weather up at manual refresh.
Arwen
