Vibrate Incoming Call when on Do Not Disturb
mpcook
50
Can the S25 Ultra vibrate (no ring tone) when there is an incoming call when the phone is on Do Not Disturb? I am sure I had an Android phone at one time that could do this. But maybe my memory is failing. Would like the same on an incoming text.
I don't think so, directly... but you can change ringtone/phone behavior with Routines, so you could make it happen that way (i.e. When entering a DND routine, allow calls but set the phone to vibrate... when exiting, return the phone to allow ringtone)
Reactions: Laura Knotek
Unless I'm misunderstanding the question, that is how my phone is set up. DND is set for 10pm - 7am. My ringtone is always on vibrate. So it vibrates only for the people who are able to get through on DND, my favorites.
I want my phone to ring except when in DND when I want it to vibrate.
Yep, I have one that turns my wifi on/off by location. I will work on this one. Thanks for the advice.
On the S25 Ultra, this is difficult. I finally asked ChatGPT and it gave me step by step options only for manually setting this on/off through a mode or a routine. So, I am still looking for a means to automate it.
Not sure how this is proving difficult. Just create a routine that IF you're in a specific mode (or manually started), THEN you switch your call profile to either audio or vibrate or silent. Easy peasy!
Just create a routine with the same parameters as your DnD.
For instance, my DnD is set to turn on at 20:30 and turn off at 06:00 with only my favorite contacts ringing my phone. If I wanted to my phone to vibrate during DnD I would create a routine IF: 20:30 - 06:00, THEN: set sound mode to vibrate, and at 06:00 sound mode would return to mode it was before the routine started.
Lassi876
