Visual Voice Mail?
What app do you use to capture a screen shot?
I used capture it on my Blackberry
What is the best android one?
Do not need an app. Press home and power button together and it will take a screen shot.
This POS won't work for me.
Every time it asks me to put in a password. it will process something for a few mins, then error out.
I bet its no where near as fluid as iPhone VVM.
LOL ... login to your vm account via the 1 key on the dialer. Enter your passcode then go into the admin section and turn off the password prompt.
Dandy. Thanks.
As for visual voicemail, they turned mine off when I switched from a BB
Had to go back to the store for them to swap sim cards. Morons.
call 611 or go to a store... i don't think it can be done on myatt but you can check...
Does the VVM addon incur an extra monthly charge? If so, I'm flummoxed - why would VVM be "free" on iPhone, yet incur an addt'l monthly fee on droid
Sorry, that infact did not work. I turned it on, tried again. I turned it off, tried again to no avail.. When I enter the PW on the app, i get "Please Wait" for 2 minutes, then it says "Password not saved, try again."
Then VVM is not properly provisioned on your account. That is a new PW feature from a few months back due to some bad blog time...
SBASF
