Volume+ (Full Version)
This reminds me of my HTC Touch Pro WinMo days. The volume on it and several other WinMo de ices were almost inaudible. We had to tweak a system sound file using hexadecimal to raise the volume.
Thanks for the post.
I am using the +4 setting and my Galaxy Nexus (my first Android Phone) finally has a decent sound !
Same thing here for me, and it works great
Didn't work for me either. Installed fine, UI works, no change in volume. Verizon issued 4.0.2 installed
Did you tick both 'Speaker Modifications' in the speaker settings of the App?
Also go to Phone's settings->sound->music effects and make sure Volume+ is selected in the pop up.
Thanks for this. I will try to re-install and go further into it,
Man, I can't get this thing to work. I got it installed, and followed all the instructions. I just don't notice any difference. Is everyone noticing a big difference in volume out, or is it subtle?
Can you elaborate on the "both" Speaker modifications you are referring to? I only see one in the free version of this app that relates to the speaker.
Click on the 1.8.0.6 link, but in about the version shows 1.8.0.5. In my download folder it does say VolumePlus1.8.0.6.apk
Is it just me or is the app not working for anyone else, installed everything fine and no matter what level I'm putting it at(not going to high in the case it does decide to work) I can not hear a difference in sound.
Your not alone. I'm assume what everyone is saying the difference being is the external speaker. It does seem to enhance that some but, it doesn't seem to change much for the headset. I've played with all the EQ settings and, it doesn't seem any better than the stock music player.
I guess I'm not really too concerned about the external speaker because I use headphones most of the time when watching a video or playing music. I'll have to test it out and see if it makes the notifications sound louder.
The 'free' version has only one 'Speaker Modifications' tick box.
The full version has '2'.
I couldn't tell if this app was working or not when I was adjusting external speaker. For the headset adjustments I plugged in my headphones and started a song. While the song was playing I opened Volume+ and made adjustments on the fly. To can clearly hear the volume levels and treble/bass change and you make changes in Volume+. I ended up with Volume at +4 and Bass boost at +8. It's definitely not going to boost the volume level enough to make your ears bleed, but it definitely helps.
Anyone know the difference between the free version on the market and this full version (even though it looks free from the link)?
After jumping through all kinds of hoops trying to download this thing, I was able to, so it appears. BTW: did you guys download a specific download manager?
Regardless...I turned on pandora and started to mess with the settings while the music was playing...no difference. I even cranked it to +15...no difference. I also put the EQ settings all down the middle.
Also, the version of the file says .6..but after installed the version in the app says .5.
Volume+ definitely boosts my speaker so I can now hear alerts and ringers :), but the headset settings don't seem to have any effect at all :-\
I turned on Virtual Room effect and set that to 4. Bass enhance, i set that to 4 as well. Then i started to notice a huge difference!
great app.
So which 2 get checked? "Speaker Mods" and "Virtual Room Effect"? And if VRE gets checked, what do I set the Virtual Room Level at? The same level as the Volume Level setting?
Here is the screenshot from my Galaxy Nexus for the ones I 'ticked' (I have the full version of the app). Click on 'Volume Level' to set the level in pop-up.
I tried '+4', as I wasn't sure if going up will damage the speaker or something. It is not loud or anything at '+4', but better than stock.
I only tried the settings for the Speaker, I found the Bluetooth volume good enough and I don't use the headset much.
From the descriptions in some screens of the 'full version' application, it seems like if the phone is 'rooted', it might work better. Mine is 'stock' and I am not planning to root it at this moment.
I hope this helps.
Lelix2603
