Volume goes to max after each song.
rupam95
130
After each song, Google play music sets the volume to the max. I don't know what can be causing this error.
Stock 4.3 root with Franco kernel. Using noozoxide instead of musicFX.
Any help is appreciated.
Since you're on custom firmware, there's probably not a lot people here can do for you. It sounds like a problem with the kernel or noozoxide. Best I can do is tell you to go back to musicFX to tell which thing the problem is with, then submit a bug report to the appropriate developer.
This seems to be an issue when I'm wearing my ear buds. Anyone else having problem with this or have a fix?
It is not a problem with the stock operating system so you really need to look to Franco, noozoxide, or both as the root of the issue.
OK, but currently I'm on stock root with stock kernel and I'm still getting the error. The only thing I have changed is the baseband to .33.
Update: It is also not an issue with Noozoxide as the problem still occurs with MusicFX on.
I'm guessing this must be a google play music app problem.
