Want to root. I am still on 2.1-update 1, build number is 1.47.651.1. The following page makes rooting the Evo from the command line look pretty easy:
The easiest 1.47.651.1 root+nand unlock you'll ever see without a gui (Updated) - xda-developers
Problem is I can't get that far.
I am following the instructions on this page to install the SDK:
http://www.androidcentral.com/sdk-driver-root-oh-my
I installed the JDK (v6 update 22), Android SDK (rev 7), and downloaded/installed the USB Driver package. The instructions say that a "Found New Hardware" message will appear after plugging in the phone (it is in USB debugging mode). That message never appeared. I am not able to use "adb pull" to back up my apps so I am pretty sure there is no connection between the cmd window and the phone. Looking for suggestions.
Also wondering if I should just do Simpleroot. I already downloaded it and it's tempting to go that route. Any pitfalls? Will I be able to get support if it fails? Will it fail?
Thx...
Thx...
