weird audio issue
rp.cavanaugh
9
Att gs 3 running liquid smooth.
When I am listening to music or a podcast with play music or podkicker, the play bar or whatever you want to call it won't behave. You can't simply move the slider with your finger to go forward or back within the track. Must hold finger in place, carefully move to and fro, and watch the time counter. If you don't it will either jump to the beginning, pause, or just up and quit on you. It's hard to describe this so I know I'm painting a crappy picture. Also, the simple act of locking the screen will make it stutter and slow down. God forbid I get a notification, that's aggravating. Full on freak out from which it has real trouble recovering.
I'll likely just switch back to cm or aokp, but is this a common issue?
Better to ask in the actual thread you downloaded the rom from..
I had an audio issue with Liquid in which it incorrectly displayed the minutes for podcasts and stuff, then I updated to their latest build and it was fixed
Sheemasharmaa
