What are you remapping bixby to?
Unfortunately you can't just hit the button again and it will turn off. I've been turning it off through the notification screen.
Ok. So there's no torch toggle command then. I'll remap it to Yahoo mail then.
Spotify... If I need to load the app in the car to start playing music then I don't need to look at it
LastPass. Makes it very easy to call it up and fill in passwords...
You should be able to do that through the OS and not have to go into LP, copy, and then the app. It should just pop up in app already.
To maximize this, you still really should use bxActions. I paid for license to open up more options.
Unlocked screen actions:
Single Press: Google Assistant Extra
Double Press: Calculator
Long Press: Flashlight
Double Press and hold: OurGroceries (list sharing with wife)
Actions on locked screen:
Single Press: Rotate through sound modes
Double Press: Camera (yes, the power button does this, but it is so high on the right that I can't easily hit it any more)
Long Press: Flashlight (keep it consistent with unlocked screen)
Double Long Press: nothing as of yet...needs to be an action good for screen being off.
Awesome! Always wanted a flashlight option. Thanks for the info.
The only problem is, you can't remap it to an assistant. Other apps yes, but not assistants.
Well yes we know that now.. if you look at the post date that was before we knew that tad bit of info ;).
mcheck
